AArch64 S+dmb.sy+pos-fri-rfi-addr-pos-addr "DMB.SYdWW Rfe PosRR Fri Rfi DpAddrdR PosRR DpAddrdW Wse" Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Ws Orig=DMB.SYdWW Rfe PosRR Fri Rfi DpAddrdR PosRR DpAddrdW Wse { 0:X1=x; 0:X3=y; 1:X1=y; 1:X7=z; 1:X11=x; } P0 | P1 ; MOV W0,#2 | LDR W0,[X1] ; STR W0,[X1] | LDR W2,[X1] ; DMB SY | MOV W3,#2 ; MOV W2,#1 | STR W3,[X1] ; STR W2,[X3] | LDR W4,[X1] ; | EOR W5,W4,W4 ; | LDR W6,[X7,W5,SXTW] ; | LDR W8,[X7] ; | EOR W9,W8,W8 ; | MOV W10,#1 ; | STR W10,[X11,W9,SXTW] ; Observed y=2; x=1; 1:X4=2; 1:X2=0; 1:X0=1;
