AArch64 MP+dmb.sy+pos-fri-rfi-addr "DMB.SYdWW Rfe PosRR Fri Rfi DpAddrdR Fre" Cycle=Rfi DpAddrdR Fre DMB.SYdWW Rfe PosRR Fri Relax= Safe=Rfi Rfe Fri Fre PosRR DMB.SYdWW DpAddrdR Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMB.SYdWW Rfe PosRR Fri Rfi DpAddrdR Fre { 0:X1=x; 0:X3=y; 1:X1=y; 1:X7=x; } P0 | P1 ; MOV W0,#1 | LDR W0,[X1] ; STR W0,[X1] | LDR W2,[X1] ; DMB SY | MOV W3,#2 ; MOV W2,#1 | STR W3,[X1] ; STR W2,[X3] | LDR W4,[X1] ; | EOR W5,W4,W4 ; | LDR W6,[X7,W5,SXTW] ; Observed y=2; x=1; 1:X6=1; 1:X4=2; 1:X2=0; 1:X0=1;
