AArch64 MP+dmb.sy+addr-pos-fri-rfi-pos "DMB.SYdWW Rfe DpAddrdR PosRR Fri Rfi PosRR Fre" Cycle=Rfi PosRR Fre DMB.SYdWW Rfe DpAddrdR PosRR Fri Relax= Safe=Rfi Rfe Fri Fre PosRR DMB.SYdWW DpAddrdR Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMB.SYdWW Rfe DpAddrdR PosRR Fri Rfi PosRR Fre { 0:X1=x; 0:X3=y; 1:X1=y; 1:X4=x; } P0 | P1 ; MOV W0,#2 | LDR W0,[X1] ; STR W0,[X1] | EOR W2,W0,W0 ; DMB SY | LDR W3,[X4,W2,SXTW] ; MOV W2,#1 | LDR W5,[X4] ; STR W2,[X3] | MOV W6,#1 ; | STR W6,[X4] ; | LDR W7,[X4] ; | LDR W8,[X4] ; Observed y=1; x=1; 1:X8=1; 1:X7=1; 1:X5=0; 1:X3=2; 1:X0=1; and y=1; x=1; 1:X8=1; 1:X7=1; 1:X5=0; 1:X3=2; 1:X0=0;
