AArch64 LB+data+pos-addr-data "DpDatadW Rfe PosRR DpAddrdR DpDatadW Rfe" Cycle=Rfe PosRR DpAddrdR DpDatadW Rfe DpDatadW Relax= Safe=Rfe PosRR DpAddrdR DpDatadW Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe PosRR DpAddrdR DpDatadW Rfe { 0:X1=x; 0:X3=y; 1:X1=y; 1:X5=z; 1:X7=x; } P0 | P1 ; LDR W0,[X1] | LDR W0,[X1] ; EOR W2,W0,W0 | LDR W2,[X1] ; ADD W2,W2,#1 | EOR W3,W2,W2 ; STR W2,[X3] | LDR W4,[X5,W3,SXTW] ; | EOR W6,W4,W4 ; | ADD W6,W6,#1 ; | STR W6,[X7] ; Observed y=1; x=1; 1:X2=0; 1:X0=1; 0:X0=0;
