AArch64 LB+data+data-rfi-fri-rfi-addr "DpDatadW Rfe DpDatadW Rfi Fri Rfi DpAddrdW Rfe" Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe DpDatadW Rfi Fri Rfi DpAddrdW Rfe { 0:X1=x; 0:X3=y; 1:X1=y; 1:X3=z; 1:X9=x; } P0 | P1 ; LDR W0,[X1] | LDR W0,[X1] ; EOR W2,W0,W0 | EOR W2,W0,W0 ; ADD W2,W2,#1 | ADD W2,W2,#1 ; STR W2,[X3] | STR W2,[X3] ; | LDR W4,[X3] ; | MOV W5,#2 ; | STR W5,[X3] ; | LDR W6,[X3] ; | EOR W7,W6,W6 ; | MOV W8,#1 ; | STR W8,[X9,W7,SXTW] ; exists (z=2 /\ 0:X0=1 /\ 1:X0=1 /\ 1:X4=1 /\ 1:X6=2)
