Test C-Will03
AArch64 C-Will03
(* Test a particular case of linux atomic_add_return, check failure
   of SC (discarded in case of LL/SC loop.
   Loop is unrolled once and value read in y by P0 is not discarded *)
0:X1=x; 0:X2=y;
1:X2=y; 1:X1=x;
 P0               | P1           ;
 MOV W0,#1        | MOV W0,#2    ;
 STR W0,[X1]      | STR W0,[X2]  ;
 MOV W3,#1        | DMB ISH      ;
 LDXR W4,[X2]     | LDR W3,[X1]  ;
 ADD W3,W4,W3     |              ;
 STLXR W5,W3,[X2] |              ;
 CBNZ W5,Fail0    |              ;
 DMB ISH          |              ;
 B Exit0          |              ;
Fail0:            |              ;
 MOV W3,#1        |              ;
 LDXR W8,[X2]     |              ;
 ADD W3,W8,W3     |              ;
 STLXR W9,W3,[X2] |              ;
 Exit0:           |              ;
locations [y;0:X8;]
exists (0:X4=0 /\ 1:X3=0/\ ~(0:X5=0) /\ 0:X9=0)
