AArch64 ARMv8-pred-addr
(* In ARMv8, an address dependency where the dataflow pathway involves
only the control of a predicated instruction or conditional branch
doesn't count as an address dependency at all.
The following test should be allowed, because the CPU can speculate
the value of 1:r2 and then perform the read of y before the read of x.
0:X7=x; 0:X8=y; 0:X9=u;
int *0:X2;
1:X7=x; 1:X8=y;
P0 | P1 ;
LDR W1,[X7] | MOV W0,#1 ;
CBNZ W1,Lelse | STR W0,[X8] ;
ADD X2,X9,#0 | DMB ST ;
B Lexit | MOV W2,#1 ;
Lelse: | STR W2,[X7] ;
ADD X2,X8,#0 | ;
Lexit: | ;
LDR W3,[X2] | ;
locations [0:X2;]
exists (0:X1=1 /\ 0:X3=0)
