AArch64 ARMv8-csel-addr (* In ARMv8, an address dependency where the dataflow pathway involves only the control of a predicated instruction doesn't count as an address dependency at all. The following test should be allowed. *) { 0:X7=x; 0:X8=y; 0:X9=u; int *0:X2; 1:X7=x; 1:X8=y; } P0 | P1 ; LDR W1,[X7] | MOV W0,#1 ; CMP W1,#0 | STR W0,[X8] ; CSEL X2,X8,X9,NE | DMB ST ; LDR W3,[X2] | MOV W2,#1 ; | STR W2,[X7] ; locations [0:X2;] exists (0:X1=1 /\ 0:X3=0)
