AArch64 MP+dmb.sy+fri-rfi-pos-addr-ctrlisb "DMB.SYdWW Rfe Fri Rfi PosRR DpAddrdR DpCtrlIsbdR Fre" Cycle=Rfi PosRR DpAddrdR DpCtrlIsbdR Fre DMB.SYdWW Rfe Fri Relax= Safe=Rfi Rfe Fri Fre PosRR DMB.SYdWW DpAddrdR DpCtrlIsbdR Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMB.SYdWW Rfe Fri Rfi PosRR DpAddrdR DpCtrlIsbdR Fre { 0:X1=x; 0:X3=y; 1:X1=y; 1:X7=z; 1:X9=x; } P0 | P1 ; MOV W0,#1 | LDR W0,[X1] ; STR W0,[X1] | MOV W2,#2 ; DMB SY | STR W2,[X1] ; MOV W2,#1 | LDR W3,[X1] ; STR W2,[X3] | LDR W4,[X1] ; | EOR W5,W4,W4 ; | LDR W6,[X7,W5,SXTW] ; | CBNZ W6,LC00 ; | LC00: ; | ISB ; | LDR W8,[X9] ; Observed y=2; x=1; 1:X8=0; 1:X4=2; 1:X3=2; 1:X0=1;
