AArch64 LB+data+pos-ctrl-fri "DpDatadW Rfe PosRR DpCtrldR Fri Rfe" Cycle=Rfe PosRR DpCtrldR Fri Rfe DpDatadW Relax= Safe=Rfe Fri PosRR DpDatadW DpCtrldR Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe PosRR DpCtrldR Fri Rfe { 0:X1=x; 0:X3=y; 1:X1=y; 1:X4=x; } P0 | P1 ; LDR W0,[X1] | LDR W0,[X1] ; EOR W2,W0,W0 | LDR W2,[X1] ; ADD W2,W2,#1 | CBNZ W2,LC00 ; STR W2,[X3] | LC00: ; | LDR W3,[X4] ; | MOV W5,#1 ; | STR W5,[X4] ; Observed y=1; x=1; 1:X3=0; 1:X2=0; 1:X0=1; 0:X0=0;
