AArch64 MP+dmb.sy+addr-fri-rfi-addr-pos "DMB.SYdWW Rfe DpAddrdR Fri Rfi DpAddrdR PosRR Fre" Cycle=Rfi DpAddrdR PosRR Fre DMB.SYdWW Rfe DpAddrdR Fri Relax= Safe=Rfi Rfe Fri Fre PosRR DMB.SYdWW DpAddrdR Prefetch=0:x=F,0:y=W,1:y=F,1:x=T Com=Rf Fr Orig=DMB.SYdWW Rfe DpAddrdR Fri Rfi DpAddrdR PosRR Fre { 0:X1=x; 0:X3=y; 1:X1=y; 1:X4=z; 1:X9=x; } P0 | P1 ; MOV W0,#1 | LDR W0,[X1] ; STR W0,[X1] | EOR W2,W0,W0 ; DMB SY | LDR W3,[X4,W2,SXTW] ; MOV W2,#1 | MOV W5,#1 ; STR W2,[X3] | STR W5,[X4] ; | LDR W6,[X4] ; | EOR W7,W6,W6 ; | LDR W8,[X9,W7,SXTW] ; | LDR W10,[X9] ; Observed z=1; y=1; x=1; 1:X8=1; 1:X6=1; 1:X3=0; 1:X10=0; 1:X0=0;
