Test S+PPO921
PPC S+PPO921
"Wse LwSyncdWW Rfe PosRR DpAddrdW PosWR DpAddrdR PosRR PosRW"
Cycle=Rfe PosRR DpAddrdW PosWR DpAddrdR PosRR PosRW Wse LwSyncdWW
Relax=
Safe=Rfe Wse PosWR PosRW PosRR LwSyncdWW DpAddrdW DpAddrdR
Prefetch=0:x=F,1:x=W
Orig=Wse LwSyncdWW Rfe PosRR DpAddrdW PosWR DpAddrdR PosRR PosRW
0:r2=x; 0:r4=y;
1:r2=y; 1:r6=z; 1:r10=x;
 P0           | P1             ;
 li r1,2      | lwz r1,0(r2)   ;
 stw r1,0(r2) | lwz r3,0(r2)   ;
 lwsync       | xor r4,r3,r3   ;
 li r3,1      | li r5,1        ;
 stw r3,0(r4) | stwx r5,r4,r6  ;
              | lwz r7,0(r6)   ;
              | xor r8,r7,r7   ;
              | lwzx r9,r8,r10 ;
              | lwz r11,0(r10) ;
              | li r12,1       ;
              | stw r12,0(r10) ;
exists
(x=2 /\ 1:r1=1)
