PPC S+PPO913 "Wse LwSyncdWW Rfe DpDatadW PosWW PosWR PosRR DpAddrdR PosRW" Cycle=Rfe DpDatadW PosWW PosWR PosRR DpAddrdR PosRW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWW PosWR PosRW PosRR LwSyncdWW DpAddrdR DpDatadW Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe DpDatadW PosWW PosWR PosRR DpAddrdR PosRW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r4=z; 1:r10=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 ; lwsync | addi r3,r3,1 ; li r3,1 | stw r3,0(r4) ; stw r3,0(r4) | li r5,2 ; | stw r5,0(r4) ; | lwz r6,0(r4) ; | lwz r7,0(r4) ; | xor r8,r7,r7 ; | lwzx r9,r8,r10 ; | li r11,1 ; | stw r11,0(r10) ; exists (x=2 /\ z=2 /\ 1:r1=1)
