Test S+PPO905
PPC S+PPO905
"Wse LwSyncdWW Rfe PosRR DpAddrdW PosWR PosRR DpAddrdR PosRW"
Cycle=Rfe PosRR DpAddrdW PosWR PosRR DpAddrdR PosRW Wse LwSyncdWW
Relax=
Safe=Rfe Wse PosWR PosRW PosRR LwSyncdWW DpAddrdW DpAddrdR
Prefetch=0:x=F,1:x=W
Orig=Wse LwSyncdWW Rfe PosRR DpAddrdW PosWR PosRR DpAddrdR PosRW
0:r2=x; 0:r4=y;
1:r2=y; 1:r6=z; 1:r11=x;
 P0           | P1              ;
 li r1,2      | lwz r1,0(r2)    ;
 stw r1,0(r2) | lwz r3,0(r2)    ;
 lwsync       | xor r4,r3,r3    ;
 li r3,1      | li r5,1         ;
 stw r3,0(r4) | stwx r5,r4,r6   ;
              | lwz r7,0(r6)    ;
              | lwz r8,0(r6)    ;
              | xor r9,r8,r8    ;
              | lwzx r10,r9,r11 ;
              | li r12,1        ;
              | stw r12,0(r11)  ;
exists
(x=2 /\ 1:r1=1)
