PPC S+PPO842 "Wse LwSyncdWW Rfe DpAddrdR PosRW PosWR PosRR DpCtrldW" Cycle=Rfe DpAddrdR PosRW PosWR PosRR DpCtrldW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWR PosRW PosRR LwSyncdWW DpAddrdR DpCtrldW Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe DpAddrdR PosRW PosWR PosRR DpCtrldW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r5=z; 1:r10=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 ; lwsync | lwzx r4,r3,r5 ; li r3,1 | li r6,1 ; stw r3,0(r4) | stw r6,0(r5) ; | lwz r7,0(r5) ; | lwz r8,0(r5) ; | cmpw r8,r8 ; | beq LC00 ; | LC00: ; | li r9,1 ; | stw r9,0(r10) ; exists (x=2 /\ 1:r1=1)
