PPC S+PPO801 "Wse LwSyncdWW Rfe DpDatadW PosWR PosRR DpAddrdR PosRR DpCtrldW" Cycle=Rfe DpDatadW PosWR PosRR DpAddrdR PosRR DpCtrldW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWR PosRR LwSyncdWW DpAddrdR DpDatadW DpCtrldW Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe DpDatadW PosWR PosRR DpAddrdR PosRR DpCtrldW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r4=z; 1:r9=a; 1:r12=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 ; lwsync | addi r3,r3,1 ; li r3,1 | stw r3,0(r4) ; stw r3,0(r4) | lwz r5,0(r4) ; | lwz r6,0(r4) ; | xor r7,r6,r6 ; | lwzx r8,r7,r9 ; | lwz r10,0(r9) ; | cmpw r10,r10 ; | beq LC00 ; | LC00: ; | li r11,1 ; | stw r11,0(r12) ; exists (x=2 /\ 1:r1=1)
