PPC S+PPO777 "Wse LwSyncdWW Rfe DpAddrdW PosWR PosRR PosRW PosWR DpCtrldW" Cycle=Rfe DpAddrdW PosWR PosRR PosRW PosWR DpCtrldW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWR PosRW PosRR LwSyncdWW DpAddrdW DpCtrldW Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe DpAddrdW PosWR PosRR PosRW PosWR DpCtrldW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r5=z; 1:r11=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 ; lwsync | li r4,1 ; li r3,1 | stwx r4,r3,r5 ; stw r3,0(r4) | lwz r6,0(r5) ; | lwz r7,0(r5) ; | li r8,2 ; | stw r8,0(r5) ; | lwz r9,0(r5) ; | cmpw r9,r9 ; | beq LC00 ; | LC00: ; | li r10,1 ; | stw r10,0(r11) ; exists (x=2 /\ z=2 /\ 1:r1=1)
