PPC S+PPO635 "Wse LwSyncdWW Rfe PosRR PosRW PosWR PosRR DpAddrdR DpCtrldW" Cycle=Rfe PosRR PosRW PosWR PosRR DpAddrdR DpCtrldW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWR PosRW PosRR LwSyncdWW DpAddrdR DpCtrldW Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe PosRR PosRW PosWR PosRR DpAddrdR DpCtrldW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r9=z; 1:r11=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | lwz r3,0(r2) ; lwsync | li r4,2 ; li r3,1 | stw r4,0(r2) ; stw r3,0(r4) | lwz r5,0(r2) ; | lwz r6,0(r2) ; | xor r7,r6,r6 ; | lwzx r8,r7,r9 ; | cmpw r8,r8 ; | beq LC00 ; | LC00: ; | li r10,1 ; | stw r10,0(r11) ; exists (x=2 /\ y=2 /\ 1:r1=1)
