PPC S+PPO623 "Wse LwSyncdWW Rfe PosRR DpAddrdW PosWR PosRR DpAddrdR DpCtrldW" Cycle=Rfe PosRR DpAddrdW PosWR PosRR DpAddrdR DpCtrldW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWR PosRR LwSyncdWW DpAddrdW DpAddrdR DpCtrldW Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe PosRR DpAddrdW PosWR PosRR DpAddrdR DpCtrldW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r6=z; 1:r11=a; 1:r13=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | lwz r3,0(r2) ; lwsync | xor r4,r3,r3 ; li r3,1 | li r5,1 ; stw r3,0(r4) | stwx r5,r4,r6 ; | lwz r7,0(r6) ; | lwz r8,0(r6) ; | xor r9,r8,r8 ; | lwzx r10,r9,r11 ; | cmpw r10,r10 ; | beq LC00 ; | LC00: ; | li r12,1 ; | stw r12,0(r13) ; exists (x=2 /\ 1:r1=1)
