PPC S+PPO617 "Wse LwSyncdWW Rfe DpCtrldW PosWR DpAddrdR PosRR DpAddrdR DpCtrldW" Cycle=Rfe DpCtrldW PosWR DpAddrdR PosRR DpAddrdR DpCtrldW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWR PosRR LwSyncdWW DpAddrdR DpCtrldW Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe DpCtrldW PosWR DpAddrdR PosRR DpAddrdR DpCtrldW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r4=z; 1:r8=a; 1:r12=b; 1:r14=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | cmpw r1,r1 ; lwsync | beq LC00 ; li r3,1 | LC00: ; stw r3,0(r4) | li r3,1 ; | stw r3,0(r4) ; | lwz r5,0(r4) ; | xor r6,r5,r5 ; | lwzx r7,r6,r8 ; | lwz r9,0(r8) ; | xor r10,r9,r9 ; | lwzx r11,r10,r12 ; | cmpw r11,r11 ; | beq LC01 ; | LC01: ; | li r13,1 ; | stw r13,0(r14) ; exists (x=2 /\ 1:r1=1)
