PPC S+PPO564 "Wse LwSyncdWW Rfe PosRR PosRW PosWR PosRR DpDatadW" Cycle=Rfe PosRR PosRW PosWR PosRR DpDatadW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWR PosRW PosRR LwSyncdWW DpDatadW Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe PosRR PosRW PosWR PosRR DpDatadW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r8=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | lwz r3,0(r2) ; lwsync | li r4,2 ; li r3,1 | stw r4,0(r2) ; stw r3,0(r4) | lwz r5,0(r2) ; | lwz r6,0(r2) ; | xor r7,r6,r6 ; | addi r7,r7,1 ; | stw r7,0(r8) ; exists (x=2 /\ y=2 /\ 1:r1=1)
