PPC S+PPO412 "Wse LwSyncdWW Rfe PosRW PosWR PosRR DpDatadW PosWR DpDatadW" Cycle=Rfe PosRW PosWR PosRR DpDatadW PosWR DpDatadW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWR PosRW PosRR LwSyncdWW DpDatadW Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe PosRW PosWR PosRR DpDatadW PosWR DpDatadW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r7=z; 1:r10=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | li r3,2 ; lwsync | stw r3,0(r2) ; li r3,1 | lwz r4,0(r2) ; stw r3,0(r4) | lwz r5,0(r2) ; | xor r6,r5,r5 ; | addi r6,r6,1 ; | stw r6,0(r7) ; | lwz r8,0(r7) ; | xor r9,r8,r8 ; | addi r9,r9,1 ; | stw r9,0(r10) ; exists (x=2 /\ y=2 /\ 1:r1=1)
