PPC S+PPO375 "Wse LwSyncdWW Rfe PosRR PosRW PosWR DpAddrdW PosWR DpDatadW" Cycle=Rfe PosRR PosRW PosWR DpAddrdW PosWR DpDatadW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWR PosRW PosRR LwSyncdWW DpAddrdW DpDatadW Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe PosRR PosRW PosWR DpAddrdW PosWR DpDatadW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r8=z; 1:r11=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | lwz r3,0(r2) ; lwsync | li r4,2 ; li r3,1 | stw r4,0(r2) ; stw r3,0(r4) | lwz r5,0(r2) ; | xor r6,r5,r5 ; | li r7,1 ; | stwx r7,r6,r8 ; | lwz r9,0(r8) ; | xor r10,r9,r9 ; | addi r10,r10,1 ; | stw r10,0(r11) ; exists (x=2 /\ y=2 /\ 1:r1=1)
