PPC S+PPO278 "Wse LwSyncdWW Rfe DpAddrdW PosWR PosRW PosWR PosRR DpAddrdW" Cycle=Rfe DpAddrdW PosWR PosRW PosWR PosRR DpAddrdW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWR PosRW PosRR LwSyncdWW DpAddrdW Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe DpAddrdW PosWR PosRW PosWR PosRR DpAddrdW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r5=z; 1:r12=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 ; lwsync | li r4,1 ; li r3,1 | stwx r4,r3,r5 ; stw r3,0(r4) | lwz r6,0(r5) ; | li r7,2 ; | stw r7,0(r5) ; | lwz r8,0(r5) ; | lwz r9,0(r5) ; | xor r10,r9,r9 ; | li r11,1 ; | stwx r11,r10,r12 ; exists (x=2 /\ z=2 /\ 1:r1=1)
