Test S+PPO276
PPC S+PPO276
"Wse LwSyncdWW Rfe DpAddrdR PosRW PosWR PosRR DpAddrdW"
Cycle=Rfe DpAddrdR PosRW PosWR PosRR DpAddrdW Wse LwSyncdWW
Relax=
Safe=Rfe Wse PosWR PosRW PosRR LwSyncdWW DpAddrdW DpAddrdR
Prefetch=0:x=F,1:x=W
Orig=Wse LwSyncdWW Rfe DpAddrdR PosRW PosWR PosRR DpAddrdW
0:r2=x; 0:r4=y;
1:r2=y; 1:r5=z; 1:r11=x;
 P0           | P1              ;
 li r1,2      | lwz r1,0(r2)    ;
 stw r1,0(r2) | xor r3,r1,r1    ;
 lwsync       | lwzx r4,r3,r5   ;
 li r3,1      | li r6,1         ;
 stw r3,0(r4) | stw r6,0(r5)    ;
              | lwz r7,0(r5)    ;
              | lwz r8,0(r5)    ;
              | xor r9,r8,r8    ;
              | li r10,1        ;
              | stwx r10,r9,r11 ;
exists
(x=2 /\ 1:r1=1)
