PPC S+PPO253 "Wse LwSyncdWW Rfe PosRW PosWR DpDatadW PosWR PosRR DpAddrdW" Cycle=Rfe PosRW PosWR DpDatadW PosWR PosRR DpAddrdW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWR PosRW PosRR LwSyncdWW DpAddrdW DpDatadW Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe PosRW PosWR DpDatadW PosWR PosRR DpAddrdW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r6=z; 1:r11=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | li r3,2 ; lwsync | stw r3,0(r2) ; li r3,1 | lwz r4,0(r2) ; stw r3,0(r4) | xor r5,r4,r4 ; | addi r5,r5,1 ; | stw r5,0(r6) ; | lwz r7,0(r6) ; | lwz r8,0(r6) ; | xor r9,r8,r8 ; | li r10,1 ; | stwx r10,r9,r11 ; exists (x=2 /\ y=2 /\ 1:r1=1)
