Test S+PPO236
PPC S+PPO236
"Wse LwSyncdWW Rfe DpCtrldW PosWR PosRR DpAddrdR PosRR DpAddrdW"
Cycle=Rfe DpCtrldW PosWR PosRR DpAddrdR PosRR DpAddrdW Wse LwSyncdWW
Relax=
Safe=Rfe Wse PosWR PosRR LwSyncdWW DpAddrdW DpAddrdR DpCtrldW
Prefetch=0:x=F,1:x=W
Orig=Wse LwSyncdWW Rfe DpCtrldW PosWR PosRR DpAddrdR PosRR DpAddrdW
0:r2=x; 0:r4=y;
1:r2=y; 1:r4=z; 1:r9=a; 1:r13=x;
 P0           | P1               ;
 li r1,2      | lwz r1,0(r2)     ;
 stw r1,0(r2) | cmpw r1,r1       ;
 lwsync       | beq  LC00        ;
 li r3,1      | LC00:            ;
 stw r3,0(r4) | li r3,1          ;
              | stw r3,0(r4)     ;
              | lwz r5,0(r4)     ;
              | lwz r6,0(r4)     ;
              | xor r7,r6,r6     ;
              | lwzx r8,r7,r9    ;
              | lwz r10,0(r9)    ;
              | xor r11,r10,r10  ;
              | li r12,1         ;
              | stwx r12,r11,r13 ;
exists
(x=2 /\ 1:r1=1)
