PPC S+PPO230 "Wse LwSyncdWW Rfe PosRR PosRW PosWR DpAddrdR PosRR DpAddrdW" Cycle=Rfe PosRR PosRW PosWR DpAddrdR PosRR DpAddrdW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWR PosRW PosRR LwSyncdWW DpAddrdW DpAddrdR Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe PosRR PosRW PosWR DpAddrdR PosRR DpAddrdW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r8=z; 1:r12=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | lwz r3,0(r2) ; lwsync | li r4,2 ; li r3,1 | stw r4,0(r2) ; stw r3,0(r4) | lwz r5,0(r2) ; | xor r6,r5,r5 ; | lwzx r7,r6,r8 ; | lwz r9,0(r8) ; | xor r10,r9,r9 ; | li r11,1 ; | stwx r11,r10,r12 ; exists (x=2 /\ y=2 /\ 1:r1=1)
