PPC S+PPO227 "Wse LwSyncdWW Rfe DpCtrldW PosWW PosWR DpAddrdR PosRR DpAddrdW" Cycle=Rfe DpCtrldW PosWW PosWR DpAddrdR PosRR DpAddrdW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWW PosWR PosRR LwSyncdWW DpAddrdW DpAddrdR DpCtrldW Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe DpCtrldW PosWW PosWR DpAddrdR PosRR DpAddrdW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r4=z; 1:r9=a; 1:r13=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | cmpw r1,r1 ; lwsync | beq LC00 ; li r3,1 | LC00: ; stw r3,0(r4) | li r3,1 ; | stw r3,0(r4) ; | li r5,2 ; | stw r5,0(r4) ; | lwz r6,0(r4) ; | xor r7,r6,r6 ; | lwzx r8,r7,r9 ; | lwz r10,0(r9) ; | xor r11,r10,r10 ; | li r12,1 ; | stwx r12,r11,r13 ; exists (x=2 /\ z=2 /\ 1:r1=1)
