PPC S+PPO224 "Wse LwSyncdWW Rfe PosRR DpCtrldW PosWR DpAddrdR PosRR DpAddrdW" Cycle=Rfe PosRR DpCtrldW PosWR DpAddrdR PosRR DpAddrdW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWR PosRR LwSyncdWW DpAddrdW DpAddrdR DpCtrldW Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe PosRR DpCtrldW PosWR DpAddrdR PosRR DpAddrdW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r5=z; 1:r9=a; 1:r13=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | lwz r3,0(r2) ; lwsync | cmpw r3,r3 ; li r3,1 | beq LC00 ; stw r3,0(r4) | LC00: ; | li r4,1 ; | stw r4,0(r5) ; | lwz r6,0(r5) ; | xor r7,r6,r6 ; | lwzx r8,r7,r9 ; | lwz r10,0(r9) ; | xor r11,r10,r10 ; | li r12,1 ; | stwx r12,r11,r13 ; exists (x=2 /\ 1:r1=1)
