PPC S+PPO152 "Wse LwSyncdWW Rfe PosRR PosRW PosWR DpCtrldW PosWR DpAddrdW" Cycle=Rfe PosRR PosRW PosWR DpCtrldW PosWR DpAddrdW Wse LwSyncdWW Relax= Safe=Rfe Wse PosWR PosRW PosRR LwSyncdWW DpAddrdW DpCtrldW Prefetch=0:x=F,1:x=W Orig=Wse LwSyncdWW Rfe PosRR PosRW PosWR DpCtrldW PosWR DpAddrdW { 0:r2=x; 0:r4=y; 1:r2=y; 1:r7=z; 1:r11=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | lwz r3,0(r2) ; lwsync | li r4,2 ; li r3,1 | stw r4,0(r2) ; stw r3,0(r4) | lwz r5,0(r2) ; | cmpw r5,r5 ; | beq LC00 ; | LC00: ; | li r6,1 ; | stw r6,0(r7) ; | lwz r8,0(r7) ; | xor r9,r8,r8 ; | li r10,1 ; | stwx r10,r9,r11 ; exists (x=2 /\ y=2 /\ 1:r1=1)
