Test S+PPO045
PPC S+PPO045
"Wse LwSyncdWW Rfe PosRR PosRW PosWR DpAddrdR DpAddrdW"
Cycle=Rfe PosRR PosRW PosWR DpAddrdR DpAddrdW Wse LwSyncdWW
Relax=
Safe=Rfe Wse PosWR PosRW PosRR LwSyncdWW DpAddrdW DpAddrdR
Prefetch=0:x=F,1:x=W
Orig=Wse LwSyncdWW Rfe PosRR PosRW PosWR DpAddrdR DpAddrdW
0:r2=x; 0:r4=y;
1:r2=y; 1:r8=z; 1:r11=x;
 P0           | P1              ;
 li r1,2      | lwz r1,0(r2)    ;
 stw r1,0(r2) | lwz r3,0(r2)    ;
 lwsync       | li r4,2         ;
 li r3,1      | stw r4,0(r2)    ;
 stw r3,0(r4) | lwz r5,0(r2)    ;
              | xor r6,r5,r5    ;
              | lwzx r7,r6,r8   ;
              | xor r9,r7,r7    ;
              | li r10,1        ;
              | stwx r10,r9,r11 ;
exists
(x=2 /\ y=2 /\ 1:r1=1)
