PPC MP+PPO939 "Fre LwSyncdWW Rfe DpAddrdR PosRR DpAddrdR DpCtrldW PosWR PosRR" Cycle=Rfe DpAddrdR PosRR DpAddrdR DpCtrldW PosWR PosRR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWR PosRR LwSyncdWW DpAddrdR DpCtrldW Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe DpAddrdR PosRR DpAddrdR DpCtrldW PosWR PosRR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r5=z; 1:r9=a; 1:r11=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 ; lwsync | lwzx r4,r3,r5 ; li r3,1 | lwz r6,0(r5) ; stw r3,0(r4) | xor r7,r6,r6 ; | lwzx r8,r7,r9 ; | cmpw r8,r8 ; | beq LC00 ; | LC00: ; | li r10,1 ; | stw r10,0(r11) ; | lwz r12,0(r11) ; | lwz r13,0(r11) ; exists (x=2 /\ 1:r1=1 /\ 1:r13=1)
