PPC MP+PPO901 "Fre LwSyncdWW Rfe PosRW PosWR PosRR DpAddrdW PosWR PosRR" Cycle=Rfe PosRW PosWR PosRR DpAddrdW PosWR PosRR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWR PosRW PosRR LwSyncdWW DpAddrdW Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe PosRW PosWR PosRR DpAddrdW PosWR PosRR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r8=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | li r3,2 ; lwsync | stw r3,0(r2) ; li r3,1 | lwz r4,0(r2) ; stw r3,0(r4) | lwz r5,0(r2) ; | xor r6,r5,r5 ; | li r7,1 ; | stwx r7,r6,r8 ; | lwz r9,0(r8) ; | lwz r10,0(r8) ; exists (x=2 /\ y=2 /\ 1:r1=1 /\ 1:r10=1)
