PPC MP+PPO876 "Fre LwSyncdWW Rfe DpCtrldW PosWR DpAddrdR DpAddrdW PosWR PosRR" Cycle=Rfe DpCtrldW PosWR DpAddrdR DpAddrdW PosWR PosRR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWR PosRR LwSyncdWW DpAddrdW DpAddrdR DpCtrldW Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe DpCtrldW PosWR DpAddrdR DpAddrdW PosWR PosRR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r4=z; 1:r8=a; 1:r11=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | cmpw r1,r1 ; lwsync | beq LC00 ; li r3,1 | LC00: ; stw r3,0(r4) | li r3,1 ; | stw r3,0(r4) ; | lwz r5,0(r4) ; | xor r6,r5,r5 ; | lwzx r7,r6,r8 ; | xor r9,r7,r7 ; | li r10,1 ; | stwx r10,r9,r11 ; | lwz r12,0(r11) ; | lwz r13,0(r11) ; exists (x=2 /\ 1:r1=1 /\ 1:r13=1)
