PPC MP+PPO873 "Fre LwSyncdWW Rfe DpAddrdR DpAddrdW PosWR PosRR" Cycle=Rfe DpAddrdR DpAddrdW PosWR PosRR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWR PosRR LwSyncdWW DpAddrdW DpAddrdR Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe DpAddrdR DpAddrdW PosWR PosRR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r5=z; 1:r8=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 ; lwsync | lwzx r4,r3,r5 ; li r3,1 | xor r6,r4,r4 ; stw r3,0(r4) | li r7,1 ; | stwx r7,r6,r8 ; | lwz r9,0(r8) ; | lwz r10,0(r8) ; exists (x=2 /\ 1:r1=1 /\ 1:r10=1)
