PPC MP+PPO851 "Fre LwSyncdWW Rfe DpAddrdW PosWR DpAddrdR PosRR DpAddrdR PosRR" Cycle=Rfe DpAddrdW PosWR DpAddrdR PosRR DpAddrdR PosRR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWR PosRR LwSyncdWW DpAddrdW DpAddrdR Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe DpAddrdW PosWR DpAddrdR PosRR DpAddrdR PosRR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r5=z; 1:r9=a; 1:r13=x; } P0 | P1 ; li r1,1 | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 ; lwsync | li r4,1 ; li r3,1 | stwx r4,r3,r5 ; stw r3,0(r4) | lwz r6,0(r5) ; | xor r7,r6,r6 ; | lwzx r8,r7,r9 ; | lwz r10,0(r9) ; | xor r11,r10,r10 ; | lwzx r12,r11,r13 ; | lwz r14,0(r13) ; exists (1:r1=1 /\ 1:r14=0)
