PPC MP+PPO840 "Fre LwSyncdWW Rfe DpAddrdR PosRW PosWW PosWR DpAddrdR PosRR" Cycle=Rfe DpAddrdR PosRW PosWW PosWR DpAddrdR PosRR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWW PosWR PosRW PosRR LwSyncdWW DpAddrdR Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe DpAddrdR PosRW PosWW PosWR DpAddrdR PosRR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r5=z; 1:r11=x; } P0 | P1 ; li r1,1 | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 ; lwsync | lwzx r4,r3,r5 ; li r3,1 | li r6,1 ; stw r3,0(r4) | stw r6,0(r5) ; | li r7,2 ; | stw r7,0(r5) ; | lwz r8,0(r5) ; | xor r9,r8,r8 ; | lwzx r10,r9,r11 ; | lwz r12,0(r11) ; exists (z=2 /\ 1:r1=1 /\ 1:r12=0)
