PPC MP+PPO832 "Fre LwSyncdWW Rfe DpAddrdR DpAddrdW PosWW PosWR DpAddrdR PosRR" Cycle=Rfe DpAddrdR DpAddrdW PosWW PosWR DpAddrdR PosRR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWW PosWR PosRR LwSyncdWW DpAddrdW DpAddrdR Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe DpAddrdR DpAddrdW PosWW PosWR DpAddrdR PosRR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r5=z; 1:r8=a; 1:r13=x; } P0 | P1 ; li r1,1 | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 ; lwsync | lwzx r4,r3,r5 ; li r3,1 | xor r6,r4,r4 ; stw r3,0(r4) | li r7,1 ; | stwx r7,r6,r8 ; | li r9,2 ; | stw r9,0(r8) ; | lwz r10,0(r8) ; | xor r11,r10,r10 ; | lwzx r12,r11,r13 ; | lwz r14,0(r13) ; exists (a=2 /\ 1:r1=1 /\ 1:r14=0)
