PPC MP+PPO800 "Fre LwSyncdWW Rfe PosRW PosWR DpAddrdR PosRR PosRW PosWR" Cycle=Rfe PosRW PosWR DpAddrdR PosRR PosRW PosWR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWR PosRW PosRR LwSyncdWW DpAddrdR Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe PosRW PosWR DpAddrdR PosRR PosRW PosWR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r7=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | li r3,2 ; lwsync | stw r3,0(r2) ; li r3,1 | lwz r4,0(r2) ; stw r3,0(r4) | xor r5,r4,r4 ; | lwzx r6,r5,r7 ; | lwz r8,0(r7) ; | li r9,1 ; | stw r9,0(r7) ; | lwz r10,0(r7) ; exists (x=2 /\ y=2 /\ 1:r1=1 /\ 1:r10=1)
