PPC MP+PPO797 "Fre LwSyncdWW Rfe DpAddrdW PosWR DpAddrdR PosRR PosRW PosWR" Cycle=Rfe DpAddrdW PosWR DpAddrdR PosRR PosRW PosWR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWR PosRW PosRR LwSyncdWW DpAddrdW DpAddrdR Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe DpAddrdW PosWR DpAddrdR PosRR PosRW PosWR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r5=z; 1:r9=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 ; lwsync | li r4,1 ; li r3,1 | stwx r4,r3,r5 ; stw r3,0(r4) | lwz r6,0(r5) ; | xor r7,r6,r6 ; | lwzx r8,r7,r9 ; | lwz r10,0(r9) ; | li r11,1 ; | stw r11,0(r9) ; | lwz r12,0(r9) ; exists (x=2 /\ 1:r1=1 /\ 1:r12=1)
