PPC MP+PPO700 "Fre LwSyncdWW Rfe PosRR DpAddrdR PosRR DpAddrdR DpCtrldW PosWR" Cycle=Rfe PosRR DpAddrdR PosRR DpAddrdR DpCtrldW PosWR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWR PosRR LwSyncdWW DpAddrdR DpCtrldW Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe PosRR DpAddrdR PosRR DpAddrdR DpCtrldW PosWR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r6=z; 1:r10=a; 1:r12=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | lwz r3,0(r2) ; lwsync | xor r4,r3,r3 ; li r3,1 | lwzx r5,r4,r6 ; stw r3,0(r4) | lwz r7,0(r6) ; | xor r8,r7,r7 ; | lwzx r9,r8,r10 ; | cmpw r9,r9 ; | beq LC00 ; | LC00: ; | li r11,1 ; | stw r11,0(r12) ; | lwz r13,0(r12) ; exists (x=2 /\ 1:r1=1 /\ 1:r13=1)
