PPC MP+PPO659 "Fre LwSyncdWW Rfe DpAddrdR PosRR DpDatadW PosWR" Cycle=Rfe DpAddrdR PosRR DpDatadW PosWR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWR PosRR LwSyncdWW DpAddrdR DpDatadW Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe DpAddrdR PosRR DpDatadW PosWR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r5=z; 1:r8=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 ; lwsync | lwzx r4,r3,r5 ; li r3,1 | lwz r6,0(r5) ; stw r3,0(r4) | xor r7,r6,r6 ; | addi r7,r7,1 ; | stw r7,0(r8) ; | lwz r9,0(r8) ; exists (x=2 /\ 1:r1=1 /\ 1:r9=1)
