PPC MP+PPO579 "Fre LwSyncdWW Rfe PosRR DpDatadW PosWR PosRR DpAddrdW PosWR" Cycle=Rfe PosRR DpDatadW PosWR PosRR DpAddrdW PosWR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWR PosRR LwSyncdWW DpAddrdW DpDatadW Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe PosRR DpDatadW PosWR PosRR DpAddrdW PosWR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r5=z; 1:r10=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | lwz r3,0(r2) ; lwsync | xor r4,r3,r3 ; li r3,1 | addi r4,r4,1 ; stw r3,0(r4) | stw r4,0(r5) ; | lwz r6,0(r5) ; | lwz r7,0(r5) ; | xor r8,r7,r7 ; | li r9,1 ; | stwx r9,r8,r10 ; | lwz r11,0(r10) ; exists (x=2 /\ 1:r1=1 /\ 1:r11=1)
