PPC MP+PPO520 "Fre LwSyncdWW Rfe PosRW PosWR PosRR DpAddrdR DpAddrdW PosWR" Cycle=Rfe PosRW PosWR PosRR DpAddrdR DpAddrdW PosWR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWR PosRW PosRR LwSyncdWW DpAddrdW DpAddrdR Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe PosRW PosWR PosRR DpAddrdR DpAddrdW PosWR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r8=z; 1:r11=x; } P0 | P1 ; li r1,2 | lwz r1,0(r2) ; stw r1,0(r2) | li r3,2 ; lwsync | stw r3,0(r2) ; li r3,1 | lwz r4,0(r2) ; stw r3,0(r4) | lwz r5,0(r2) ; | xor r6,r5,r5 ; | lwzx r7,r6,r8 ; | xor r9,r7,r7 ; | li r10,1 ; | stwx r10,r9,r11 ; | lwz r12,0(r11) ; exists (x=2 /\ y=2 /\ 1:r1=1 /\ 1:r12=1)
