PPC MP+PPO210 "Fre LwSyncdWW Rfe DpDatadW PosWR PosRW PosWR PosRR DpAddrdR" Cycle=Rfe DpDatadW PosWR PosRW PosWR PosRR DpAddrdR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWR PosRW PosRR LwSyncdWW DpAddrdR DpDatadW Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe DpDatadW PosWR PosRW PosWR PosRR DpAddrdR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r4=z; 1:r11=x; } P0 | P1 ; li r1,1 | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 ; lwsync | addi r3,r3,1 ; li r3,1 | stw r3,0(r4) ; stw r3,0(r4) | lwz r5,0(r4) ; | li r6,2 ; | stw r6,0(r4) ; | lwz r7,0(r4) ; | lwz r8,0(r4) ; | xor r9,r8,r8 ; | lwzx r10,r9,r11 ; exists (z=2 /\ 1:r1=1 /\ 1:r10=0)
