PPC MP+PPO160 "Fre LwSyncdWW Rfe DpAddrdR PosRW PosWR DpAddrdR PosRR DpAddrdR" Cycle=Rfe DpAddrdR PosRW PosWR DpAddrdR PosRR DpAddrdR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWR PosRW PosRR LwSyncdWW DpAddrdR Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe DpAddrdR PosRW PosWR DpAddrdR PosRR DpAddrdR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r5=z; 1:r10=a; 1:r14=x; } P0 | P1 ; li r1,1 | lwz r1,0(r2) ; stw r1,0(r2) | xor r3,r1,r1 ; lwsync | lwzx r4,r3,r5 ; li r3,1 | li r6,1 ; stw r3,0(r4) | stw r6,0(r5) ; | lwz r7,0(r5) ; | xor r8,r7,r7 ; | lwzx r9,r8,r10 ; | lwz r11,0(r10) ; | xor r12,r11,r11 ; | lwzx r13,r12,r14 ; exists (1:r1=1 /\ 1:r13=0)
