PPC MP+PPO026 "Fre LwSyncdWW Rfe PosRR DpAddrdR PosRR DpAddrdW PosWR DpAddrdR" Cycle=Rfe PosRR DpAddrdR PosRR DpAddrdW PosWR DpAddrdR Fre LwSyncdWW Relax= Safe=Rfe Fre PosWR PosRR LwSyncdWW DpAddrdW DpAddrdR Prefetch=1:x=T Com=Rf Fr Orig=Fre LwSyncdWW Rfe PosRR DpAddrdR PosRR DpAddrdW PosWR DpAddrdR { 0:r2=x; 0:r4=y; 1:r2=y; 1:r6=z; 1:r10=a; 1:r14=x; } P0 | P1 ; li r1,1 | lwz r1,0(r2) ; stw r1,0(r2) | lwz r3,0(r2) ; lwsync | xor r4,r3,r3 ; li r3,1 | lwzx r5,r4,r6 ; stw r3,0(r4) | lwz r7,0(r6) ; | xor r8,r7,r7 ; | li r9,1 ; | stwx r9,r8,r10 ; | lwz r11,0(r10) ; | xor r12,r11,r11 ; | lwzx r13,r12,r14 ; exists (1:r1=1 /\ 1:r13=0)
