PPC LB0010 "DpDatadW Rfe DpAddrdR PosRR DpAddrdW Rfe" Cycle=Rfe DpAddrdR PosRR DpAddrdW Rfe DpDatadW Relax=[Rfe,DpDatadW,Rfe] Safe=PosRR DpAddrdW DpAddrdR Prefetch=0:x=F,0:y=W,1:y=F,1:x=W Com=Rf Rf Orig=DpDatadW Rfe DpAddrdR PosRR DpAddrdW Rfe { 0:r2=x; 0:r4=y; 1:r2=y; 1:r5=z; 1:r9=x; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | xor r3,r1,r1 ; addi r3,r3,1 | lwzx r4,r3,r5 ; stw r3,0(r4) | lwz r6,0(r5) ; | xor r7,r6,r6 ; | li r8,1 ; | stwx r8,r7,r9 ; exists (0:r1=1 /\ 1:r1=1)
