PPC LB+PPO0592 "PodRW Rfe DpDatadW Rfe PosRR PosRW PosWR PosRR" Cycle=Rfe PosRR PosRW PosWR PosRR PodRW Rfe DpDatadW Relax= Safe=Rfe PosWR PosRW PosRR Pod*W DpDatadW Prefetch= Com=Rf Rf Orig=PodRW Rfe DpDatadW Rfe PosRR PosRW PosWR PosRR { 0:r2=y; 0:r4=x; 1:r2=x; 1:r8=y; } P0 | P1 ; lwz r1,0(r2) | lwz r1,0(r2) ; xor r3,r1,r1 | lwz r3,0(r2) ; addi r3,r3,1 | li r4,2 ; stw r3,0(r4) | stw r4,0(r2) ; | lwz r5,0(r2) ; | lwz r6,0(r2) ; | li r7,1 ; | stw r7,0(r8) ; exists (x=2 /\ 0:r1=1 /\ 1:r1=1)
